Like many of you I saw a timer as a good solution to my worrying about properly charging my battery. I have a problem with the battery discharging after the timer stops, though. If the battery remains connected to the adapter and the outlet is not electrified, the battery drains. Is that likely an issue with the timer, adapter, or battery?
After getting used to using an outlet timer to charge my ebike, I also started using one on my laptop.
After Grin Tech told me they did not have the proper adapter for my Yamaha battery I bought this $9 timer from Amazon. It's very basic, only allowing hourly increments, but it works. One hour charges my battery for about 25 to 30%, two hours for 50 to 60%, etc. So, if after a ride my battery shows 25% charge left, I set the timer for two hours and the battery gets charged to just over 80%.
You can do that with the timer I posted. Set your bike to charge between 6-8 am for an 8 am commute.
50% is good for storage.
IMO you're making a mountain out of a molehill on charge state, it's not going to make that much difference over the life of your bike. Maybe in ten years you'll improve by 5%. But it's fun for some to chase it.
As long as you don't store it at 20% nor 100% you'll be fine. If you're using it the next day you can charge it overnight. Lots of machinations for very little payoff. After two thousand cycles it MIGHT make a few percent difference. I'll be dead by then.
A timer is a simple, inexpensive solution to optimizing battery life... YMMV.
I totally agree, I use one myself now thanks to many people on EBR suggesting it (and thanks to all those people!).
My question is what to do when I have, say, a 35% charge after a ride, and I intend to ride again the next day. Is it optimal to leave it at 35% for half a day, or optimal to top it up to something like 50% after the ride? This would be with the intention of further topping it up to 80% (or whatever I decide I need for the length of ride I have planned) shortly before the next ride.
Don't know if you are looking for a 110v relay, but I've used this one with good success.I'm planning to make something based on a arduino type microcontroller that will be in-line with a regular charger to make it semi-smart ...
If I monitor the charge voltage, I can set this device to cut power (Probably just open a relay) when the battery reaches a set value.
If I include a knob and a small display, I can make the charge value whatever I want for a particular day.
Most likely be set to 80% most of the time, but would allow me to move it around if desired.
Initially, It will be just for my current 48V, 2A charger, but there is no reason I can't update the program in the future to have various pack voltages or chemistry profiles pre-set to make it easy to switch between chargers.
It won't have the monitoring / tracking / history capabilities of the satiator, and I won't be able to adjust the maximum charge current, but should only cost about $10 - $15 in parts, and be usable with any (48V initially) charger.
I'm sure this is possible - The main unknown at the moment is the best way to check the voltage (charging voltage going in Vs Voltage at the discharge port) and how that relates to the actual battery charge state - Basically, how much do I need to worry about the BMS . (Not too hard to figure out, just have to sit down and do it)
I'm also sure I can add other functions, such as:
a timer or even a 2-part charge profile like those 'fancy' timers mentioned above.
Total Charge info - ie, how many WHrs Just went in. (much easier than long term tracking)
If it works as expected, I may make up a proper housing for it and maybe even design a circuit board to make it really sleek.
Now to just find the time! (I barely even have time to ride the bike, other than my commute.)
				 www.adafruit.com
					www.adafruit.com
				Don't overthink this. It's more like a "best practices" guide, and much of it is guaranteed to work on paper but nowhere else. Also, I believe it's super important to get a full (balance) charge frequently for best performance/longevity. Point being, you need to weigh the need for that when going with the timer plan.
To answer your question, I would charge right away so I didn't have to try and remember to charge just prior to my ride.
