6zfshdb
 - USA
- City
 - Northeast Pennsylvania
I usually carry quite a bit of gear when I ride and almost always use panniers.  Although Pedego makes a couple of panniers that fit the extra wide rear rack, none are high quality and aren't suitable for my cargo.  I'm partial to the high quality Arkel quick attach products and have been using them on my Treks for years.  I have their T42:  https://www.arkel-od.com/t-42-lite-touring-panniers/  and smaller T28: https://www.arkel-od.com/t-28-lite-touring-bicycle-panniers/.  I was sorry to find that neither would fit the Pedego rack due to clearance issues with the battery box.
There are Velcro strap, saddle and bungee style panniers out there that fit but I much prefer the individual quick attach type. They install & remove in seconds and can be used individually if desired. Since I already have quite an investment in the Arkel products, I made up this adapter that fits the Pedego rear rack. Although Arkel is used here, the adapter can be used with almost any pannier. It is corrosion resistant and easily removed without marring the bike finish.
The adapter is made from two 12" pieces of 1/2" aluminum tubing: https://www.lowes.com/pd/Hillman-3-ft-Aluminum-Plain-Tube/3053611
Four 5/8" insulated cable clamps: https://www.lowes.com/pd/Hillman-2-Pack-5-8-in-dia-Steel-Suspension-Clamp/3013246
Four 1/2" insulated cable clamps: https://www.lowes.com/pd/Hillman-2-Pack-1-2-in-dia-Steel-Suspension-Clamp/3013245
Four 10/24 allen head cap screws: https://www.lowes.com/pd/Hillman-10-24-x-1-2-in-Allen-Drive-Cap-Screws-4-Count/3024576
Four 10/24 nylon lock nuts: https://www.lowes.com/pd/Hillman-8-...l-Standard-SAE-Nylon-Insert-Lock-Nuts/4756347
For decoration but not necessary for function, four 1/2" tubing caps: https://www.amazon.com/gp/product/B07HJ1PR89/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
