Wondering if owners of the 2019 RR might chime in with range / speed numbers when using throttle only, relatively flat ground. Want to get a minimum range figure (knees bad, cannot pedal as much as I'd like).
Can the Rad Rover, as heavy as it is, get past 20mph on level pavement? (I assume you have to program the display for a higher than "stock" speed allowed - I guess it leaves the factory set for 20mph, but not sure it can go faster than that even if the limiter is set higher?)
On level, mostly pavement, what kind of range can be expected (no pedaling at all) on a full battery?
This will give me worst case scenario.
Thanks!
Thanks!
