@CodyDog, just checked the specs for your Rad Rover and that suspension fork has a lockout adjustment at the top of the forks. This would be the equivalent of riding with a rigid fork without spending $$ and labor for different forks. Unfortunately, neither the Rad Power site nor the Owner's Manual for your ebike mention the brand & model of suspension fork you have so I can't be more specific. Get that info off of the fork and do an internet search for instructions on how to set your fork. You may have gotten a separate info sheet along with the Owner's Manual that's just for the fork, too.
Locking out the suspension is not equivalent. Suspensions, especially low end ones, are very heavy.
I swapped out the suspension on my Juiced CCS and it made the front end way lighter and more agile. In tandem with a plush 2.35" G-One speed balloon tire, it was an excellent improvement. Highly recommend.
I went with a Salsa CroMoto. Talk to a local bike shop that sells Salsa, and ask them if it will be compatible, and if so order one through them.
I looked around for other steel rigid forks with wide clearance, that was the best option I found (recommended by Ravi Kempaiah, the forum member with the Guinness record for ebiking).
Do you know if there's an online guide to explain the presets on the fork or is it just left up to experimentation? All new to me.I did tighten up the forks with the knob opposite of the lock/open button along with changing out the tires to Vee8 120 tpi set to 20-23 psi.
Going for it? If so, let me know how it works out. Does it have bosses for a front fender?I went to my LBS today to look for a rigid fork for my Rad. The only one we could come up with that matches the demeinsions of the 2018 Rad RST suspension fork was a Surly Pugsley Fork 135mm Hub Spacing 17.5mm Offset Straight Blade Black PN FK0030
It look like it weighs 2.5 pounds. Made out of Chrome Moly.
	@Asher, your post got me thinking perhaps I should look at swapping out my suspension fork too since I only use my RadRover on paved streets. I contacted Salsa Cycles with a question about compatibility with my 2018 RadRover and got the following response:
“None of our frames or forks are designed or tested around use on E-Bikes so we cannot recommend or condone doing so.” ~ Evan from Salsa Cycles
Sounds like a typical lawyer mandated CYA response, but in any case proceed at my own risk.
Checking in to see if you made the change? I would like to do the same if this fork is compatible with the 2018 RR. The the price is right, and it appears to have better mounting options for a front pannier rack?Think I'll give it a try. Here's a pic. May need to modify a fender bracket to fit what appear to be bosses on each upper side.
Any idea if the stock brakes will fit this fork?
What adapter for the brake mount was usedYes, he did make the change. Read more here: https://electricbikereview.com/foru...nd-surly-rigid-fork-are-in.24718/#post-169714
