Juiced doesn't sell a bike like the Rad Mini. Their nearest comparable model is the scrambler, which is a  cadence sensor, unless you upgrade to the top of the line model at $1000 more, but I guess you know that.
None of my ebike conversions have torque sensors (T/S) yet. I've test ridden T/S bikes. The main difference that I recall is that I can ride a T/S bike very slow under 8 mph with light pedal pressure. A cadence sensor bike will scoot up to 10+ mph when it detects the pedals moving. Scares newbies, Accordingly, when I need to maneuver slowly, I either shut off the motor or grab my brake cutoffs lightly. At regular bike speeds, I recall the T/S bikes give similar pedal resistance as my cadence units. It depends on the design. The better cadence units ones will try balance the effort from your legs and motor at higher speeds. The crap ones will not give you enough feedback. It's all motor with them.
I trust Rad didn't mess around and picked cadence systems that work better.
I also feel T/S systems are well suited for people who weren't bike enthusiasts. These are folks that don't use the gears. In that case, a system where you press harder to get power is simple to use. With a cadence sensor, if you do that in the wrong gear, the pedal don't spin and you fall over when the bike stops, unless you have a throttle.
