AHicks
- USA
- City
- Snow Bird - Summer S.E. Michigan, Winter Gulf Coast North Central Fl.
Don't do it because I said so, but if you're interested in more performance, it's something to look in to. Be aware that this would not be a "plug and play". A new non Rad controller would need it's wiring matched to the existing.
Note that the "soft start" they use was one of the big reasons I decided to totally re-power my City. It's not user definable like the LCD display and controller I went with.
Too stupid to leave well enough alone, currently looking at a MAC geared rear hub rated at nearly twice the power the stock Rover is rated at....
Point being, if you aren't happy with the power you have, it's not that expensive or difficult to fix that issue. Entire "kits" are pretty reasonably priced. The 1500w DD kit I went with, with motor and wheel all laced up, controller, LCD display, brake levers, etc. All set up to "plug and play" was less than 300. and took maybe 4 or 5 hours to install.....
