gwtach
Hey guys! I'm new to the forum and I just picked up an old 24v Iacocca folding mini e-bike for $150 with no battery.
I did some tests with my 18v makita drill batteries (wired in series to get 36V) and everything was working fine... until I accidentally crossed the jumper cables I used to connect the batteries and fried the controller. Ugh! I'm still pissed at myself for being so dumb. Well I've done a lot of reading about this bike and the various ways people have modified it, and it sounds like plenty of people are running the 24v 400watt heinzmann brush motor off of a 36v battery no problem to get more speed and power, but the controller can only handle that for so long. So instead of trying to fix this controller I'd rather find another solution so I can keep running 36v. I'm not trying to commute long distances with this thing, mainly just want it for getting to and from the train station 1 mile from my house and up a short steep hill.
So here are my questions:
1) Is it possible to run the motor directly off of the battery with a simple on/off switch instead of a controller? I already tried it briefly to make sure the motor was still working after the controller blew, but are there problems that can arise by doing this long term? I'm guessing maybe the motor could overheat? I was thinking of hooking it up this way by getting a momentary switch to use as a throttle. The switch would simply turn on and off one of the battery connections to the motor.
2) If not the above solution, does anyone have suggestions or experience using these motors with different controllers? I know I can get a 36v brush motor controller pretty cheap, but is there anything else specific I should look for? Or a certain brand of controller?
3) I know these motors have an overheat protection switch or something built into them. Does anyone have experience with this function, and how to utilize it without using the original controller?
Thanks!
Thanks!
