Trail Cruiser
I know, I know, people would quickly point out that mid drives has the advantage on steep inclines. And that is true, mid drives can take advantage of the gearing and can comfortably tackle more than 15% inclines. You would often see those steep inclines on off road single tracks, riding in the lowest gears and laboring slowly at 5 mph or less.
If you stick to designated bicycle trails and/or streets, you'll rarely encounter hills that steep on your regular route unless you go hunting for one. And that's what I experienced myself, on all my regular routes, the steepest hill I encounter is something like 12%. Both my hub drive and mid drive have no problem tackling it.
However, when I went looking for the steepest hill in my area (16-18%), my mid drive performed better and struggled less.
Unless you ride regularly on off road single tracks with really steep hills, the hub drive is an adequate setup.
If you use it for commute with speeds regularly exceeding 25 mph, then the hub drive may have the advantage mainly for longevity of the drivetrain.
