45 or 47, it does not matter. With the rims specified, you can run anything from 28 to 62mm wide (the wider dependent on frame clearance).
That sounds..weird.. but I will take your word for it. I should have no problem getting the tires I want now.
There is nothing special about the stock gearing on the bike. In fact Juiced used to offer a 10 spd option for the CCS; my guess is it was a very low volume option selection and they decided it wasn't worth the hassle to provide it any longer.Except that clearly says the ISO is 47-622. If this works then I can conclude the 45-622 on the web site is in error.
I saw all that, but he is clearly targeting a specific, different set of gear ratios than the bikes default. This will be my first bike in a long time and I would rather stick with the ratio the bike was originally designed with.
Maintenance update: i.e. CCS stock kendas. I weighed #300 when it arrived, now #230. I ride on wet grimy roads, so
I'm likely to wear out tires faster than the rest of you. Changed rear tire today at 900 mi for a 28" x 1.75 regular Schwalbe marathon.
The front kenda still looks good, (guess suspension reduces wear) I know the Schwables will roll better, but they're narrower.
I think the kendas are better for wet road, but summer's coming. Being narrower the Schwalbes are still good on wet road if
your on a regular bike, but I'm not all that sure about a heavier ebike. Anyway, if you're still on the stock kendas at 900 mi.,
you might want look at tires.
Excellent work with the weight loss.Maintenance update: i.e. CCS stock kendas. I weighed #300 when it arrived, now #230. I ride on wet grimy roads, so
If you can just find a 9 speed derailleur with a stronger tension arm spring, that may be all the fix needed.From what I saw, I have plenty of options with 9 speed cassets so if I want to play with ratios down the line I won't feel bad about sticking with a 9 speed derailleur. You seem to think I am replacing the entire drive train but I am not. Sticking with 9 speed means I get to keep the same chain, too. I simply wanted to update equipment to reduce chain drops. The derailleur is simply a must replace because they give you a $20 toy that has been shown to fail early. As for the chain ring, it seemed like a very simple replacement to upgrade to a narrow-wide, although I havnt been able to figure out if I need to buy a crank with it based on existing fittings.
Nearly all bikes experience much higher wear on the rear tire vs front. This is because our bodyweight is shifted disproportionately to the rear of the bike. Many people will rotate tires front to rear periodically to even out the wear, others just plan on replacing the rear twice as often.
As a side note, does anyone know the biggest tire that will fit without issues on a CCS?
What's with the Ancheer? I know they're cheap; is it any good?I had asked a salesman (he was male) if the stickers were removable, and he said they were, and they are not, not without voiding your warranty probably (sanding off, reapplying clear coat, etc). Someone else here reported the same thing. I'd still have bought the bike no doubt, but I'd have appreciated being told the decals were not removable from the beginning.
More generally, I think the decals detract from the bike's appearance on the brushed aluminum*, and it's easier for them to not put on any. I don't see these stickers helping Juiced sell more bikes. You'll also find that there's a general pattern of minimalist appearance ~ more premium, e.g. Stromer, Vanmoof vs Ancheer ($600 Amazon 250w ebike). I.e. you can charge more for a cleaner bike.
*On the black, it looks very tasteful, because it's low contrast. When I've checked, the black is in way shorter supply. Probably not a coincidence...
View attachment 20977View attachment 20979
I concur on the Marathon Plus being squirrely on wet surfaces. I had Specialized Nimbus before and they did much better on wet roads but a hard ride. I keep my tires at 5 psi below max because of my weight. Working on that too.Chris, Schwable maKes a 700/50. I think it's the Mondial tread pattern. It's really a long range touring tire, not a fast roller, but
a durable all-terrain. I went ahead mounted both of the regular marathons, (wish I hadn't). They are 'fast', but terrifying
on wet road. My luck, shoulda left the good kenda on the front. Hopefully that will improve once they break in, SQUIRRELY!
Actually, I lost 35# before the CCS arrived. I'm down a bit more than a 100#, but it's cost a good bit of muscle mass too. More
agile though.
ps Wish I'd gone with the Mondials.
I know this will piss some people off but you asked, what your doing wrong is, you bought a juiced bike but don't feel too bad, I did too.I am hearing streaking sounds, sort of like metal plates rubbing against each other, sometimes when I ride, only when I'm carrying a heavy load. Seems to be coming from the rear hub, and it's not brake rub which is fairly quiet and lower pitched.
What might I be doing wrong? Cargo is on the left side of the rack.
