Rear rack bike light
Marceltt
Hi people , I'm looking for a battery or rechargeable rear red bike light that would fit on my axiom rear bike rack. Any suggestions anyone ? Thanks.
I bought a Busch and Muller top light flat S battery light and T-bracket from Peter White cycles www.peterwhitecycles.com/taillights-bat.php
If you want to run a light off the ebike battery you could zip tie to the rack an LED tail light like (Link Removed - No Longer Exists).
I did the Light and Motion Vis 180 bike light, ebay or Amazon, $55-$80: https://www.amazon.com/Light-Motion...&sr=8-2&keywords=light+and+motion+vis+180+pro
I purchased two light and added the second to the rear of my helmet. I like the Light and Motion because:
- 200 lumen output to be seen day and night. I even turn it on and it can be seen during sunny days of summer in the brights southwest skies of NM.
- Micro USB rechargeable
- charge last between 4-32 hours depending on settings. I top off once a week after 45-75 miles of riding per week.
- has a pulse flash instead of the super fast blinking
- has a amber follow light only feature you can turn on so you don't night blind if someone is following you
Don't get the Vis 180 Micro because I had a hard time turning this light on/off with the power switch. Returned the Vis 180 Micro after several replacements with the same problem.
