Yolin YL80C Speed Setting (eAhora)
zzRider
Does anyone here know the button sequence to set the "LS" speed setting using the eAhora Yolin YL80C display? (This is NOT the color display, despite the "C" in the product name.) I have the eAhora XC100 eMTB but I think this display is also used on some of their folding ebikes.
I can get to only 3-4 settings but LS is not one of them. The default speed setting is 25kph but will go up to 40 if I can get to that setting.
I've attached the manual here but there is a sequence for the wheel setting but not the speed setting.
Thanks!
  • YL80C_Manual (XC100 display).pdf
The trick is to cycle through the menu by pressing the "i" button, but it does not seem to consistently work (?). eAhora sent me a video which was helpful, but not definitive.
Interestingly, although the menu says the range is 12kph to 40kph, with 25kph being the default, my XC100 eMTB was already at 40 and it allowed me to go up to 50kph (~31 mph). However, for my 350w motor and my weight of 210lbs, I did not see any speed increase. My ebike tops out at 21mph on full throttle at PAS level 3. There are additional settings I have yet to adjust that may squeeze out a few more MPH, but if I can lose 10-15 lbs, I can probably get to the advertised speed of 28mph.
I have an AM100, but looking at your manual, it looks like the same sequence. I have no problem getting there. I was able to set my speed limit to 50 km/h.
1) Press and hold + and - for two seconds
2) Press and hold - and "i" for two seconds, you should be in wheel diameter mode
3) Press the "i" again and it should go into the LS setting mode.
4) Press + to increase speed limit to desired speed
5) Press "i" to return to wheel diameter or press and hold "i" to go back to main screen
