Looking at the Speed Limit settings there's a dropdown to set the speed, a check box marked "Set" and a checkbox marked "Cruise Restrict":
If you click "Set" it will set the max speed to be whatever the dropdown is set to?
What is Cruise Restrict? Does it force your system to use the on-road speed limits?
If yes, how does it impact the dropdown + Set setting?
Or maybe it locks the motor in Cruise mode, allowing you to go into off-road speed limit territory?
Or perhaps most importantly, why does the Falco interface use the Adobe Flash icon as an indicator of when your settings have been broadcasted?!?!?! : )
Working with the Falco system has felt a lot like feeling around for a light switch in a dark room. They've built an impressive product, now they just need to fork over some money on better interface and instructional design. : )
