Voilamart 1500 /48V throttle too sensitive
Uriahsky
You barely move the throttle and the bike almost pops a wheele. Is there a way to change this so that I have less sensitivity in this twist throttle?
thanks
Kevin
What control came with your kit?
If it's a KT based control with something like an LCD3 display, I might be able to help. With that setup, if you add throttle while pedaling you get pretty much everything available. If you stop pedaling, then use the throttle, it will behave like you expect it to. A little bit of throttle gets you a little bit of power.
The controller is somewhere in the hub. It doesnt have a separate one. It is a SW900 display and I went through the manual and didn’t anything that I thought would fix it but hopefully there is.
