Started all the wiring. I am building the entire bike harness, as well as assembling the motor control wiring.
First the handle bar and headset wiring. I built the harness to feed past the steering head, and down to the horncast for a junction box. This allows the steering to be removed without cutting wires. On the stock bike it looks like this:
I will be doing it the same way, though a few wires will have conventional plugs, namely the throttle wires.
The headset looks like this:
The wires are bundled by function. Separate bundles because the space is tight, so one large bundle would not fit through the access slots in the steering. I will show that on install.
I created bundles, again by function, to go from the fusebox in the glovebox to the 72V to 12V inverter and the rear lights, and for powering the fusebox. I am grounding them with wires, no frame ground due to the 72V and 12V, that would cause big issues if mixed.
Power cut off and contactor locations, plus harnesses.
Finally, I took the plunge and cut the glovebox for the battery/power meter. I was afraid the heat would ruin the paint, but ineptness with a Dremel did it in instead!
Nonetheless, it works and should give me what I need for data. Hopefully rain will not kill it. I did seal it with hot glue to keep water out of the glovebox and fuse box.
