@Joshelley, I am starting to consider the new Como or Vado with the Enviolo Automatiq for my wife, and so I have a few questions for you if you don't mind
- Can you confirm if your Vado 5.0 IGH is the new model with the 2.2 motor that supposedly has 90Nm of torque?
- Is it the one with the Enviolo AutomatiQ system, where you set a preferred cadence, and the system shifts automatically to keep you at that cadence?
- What preferred cadence value did you set on the Enviolo?
- It does not look like the bike comes with the Enviolo Bluetooth handlebar controller that allows you to adjust your cadence on the fly, but the manual shows a custom handlebar controller that is supposed to give access to some of the Enviolo settings. So can you change the preferred Enviolo cadence using that handlebar controller, and do you see the cadence selected on the Vado display?
- Are all the Enviolo settings available on the Vado screen, or do you use the Enviolo cellphone app for them?
- What size frame do you have?
- Assuming you can insert the dropper post all the way down, what is the saddle height (ground to top of saddle) in that lowest position?
- How good is the Suspension part of the seat post, does it mostly reacts to large bumps, or also filter smaller ones?
Thank you for any feedback you can provide
Yes to # 1 & 2.
3. I have used Standard, Slow, Slower. When I am riding with my husband, who has a 2020 Vado 3, I usually use Slow or Slower. I find that I have increased physical pedal cadence since I have been riding this bike and tend to ride it at 70.
4. I can change the pedal cadence fairly easily using the handlebar controller. I also can access the Micro tuner using the same button. I haven’ used that very much yet. My cadence level (fast-slowest) only shows on the cadence selection screen. The actual cadence (74, 70, 69…) shows on the first screen in a green or red strip, indicating wether it is using optimal power. I think it has actually helped me improve my overall cadence when riding.
5. Enviolo settings are definitely available on the MasterMind screen. I am not aware of a specific Enviolo cell[hone app other than the
Specialized Mission Control. I recommend you download the manual from the Specialized website for details on the MasterMind control. I really like it and find it much more usable than the one on my 2020 Vado 3.
6. I have a medium frame. I am a 5’5” woman.
7. You can probably find the saddle height in the specs.
8. I am using the standard seat that came with the bike, and have just ridden it on paved roads, but it seems to handle bumps well. Actually, I don’t see that much difference from the Vado 3 which doesn’t have a suspension seat.
I am getting spoiled with the automatic. I can’t feel when it changes gear. I have added the gear diagram, which show what gear I am in, to the front screen of MM, to give me an indication of how the bike is working as I get to know it. I did not like the feel of the Smart Control Mode, so I haven’t used it very much yet. The bike is fantastic on my steep driveway, about a 85 ft 15% grade, much better than my Vado 3. It is a little better than the Vado 3 on a 1/4 mile 12% grade hill near my house.
When the motor is running, it has a quiet hum that my Vado 3 did not have. Hope this information helps you with your decision.
