All the same! 5 volts DC in the same range as a USB wall charger. Reention supplies a decent PCB used in all cases with USB port.Does anyone know what the rated amp output is for the USB port on the Reention battery? And whether it varies depending on the battery capacity (13Ah, 16Ah, 19Ah, etc.)?
Typically 500mA - 900mA from all Reention PCBs’Hi Fred
From Moscow owner manual
G USB Port (output: 5V 700mA)
Thanks! Turns out there were 2 problems at work here. (1) The bike battery's USB port is indeed defective. (2) I inadvertently set RideWithGPS for max power consumption.Hi Jeremy, Maybe take an external "Phone Battery Bank" with you & recharge your Ph from that.
