His bike is a 2020 Explore E+. I believe close to this model. https://www.giant-bicycles.com/us/explore-eplus-4-gtsJohnny... I own a 2020 Trance E+
It doesn't really have an in tube battery, more like a case that seamlessly follows the frame.
It means Jim can order the 500 Wh battery but in the format of your battery, Paul. Thanks!500Wh battery from my 2020 Explore E+1. Since we're measuring 365mm tip to tip
The larger format EnergyPaks also seamlessly insert into the frame. One of the best designs of the battery integration I could see so far.more like a case that seamlessly follows the frame.
Here you go...the Explore uses the side release battery https://www.giantvancouver.com/ca/e-bike-gearIt means Jim can order the 500 Wh battery but in the format of your battery, Paul. Thanks!
He is right about one thing, 48V is better than 36V in terms of efficiency. I don't see the point of these so called major players staying with 36V unless it is some compatibility(but they are not even interchangeable) or legal regulation(maybe this is the reason) problem.
I took your advice and ignored him...I'm so sorry Ebiker01 that Bosch, Brose/Specialized, Yamaha/Giant, Shimano, Mahle and some other cannot or don't want to make your dreams come true.
Good for you. You didn't provide any facts to your earlier critique. Amateur !I took your advice and ignored him...
