It all depends on what the manufacturer has done, and your use of the bike. If they have done a good job it is mostly for the finicky
But it does also depend on your use of the bike.
Cadence sensing is mostly an ON/OFF switch based on detecting some pedaling (controllers can add some intelligence to that).
It is good for pedaling at regular speed (streets, smooth trails) because it maintains the assist regardless of how hard you press on the pedal.
Because of that when riding conditions change abruptly, it can cause unwanted assist.
Torque sensing is proportional to the pressure you put on the pedal.
It is best when you constantly need to adjust the assist because of the terrain (like off road riding) because you get instant modulation based on the need you express with your legs.
Because it responds to your effort, it can provide irregular assist when you pedal at constant speed where your pressure on the pedal is intermittent (again controllers can help with some smoothing).
The intelligence of the blending is meant to strike a compromise based on the detected conditions. How good it is, depends on how sophisticated the controller and its programming is...
So if your use is extremely bias in one or the other, you may wish for a little tweaking towards that use.
