Mr. Coffee
- USA
- City
- A Demented Corner of the North Cascades
If you go on a long bike tour, you will inevitably have mechanical problems. Bikes break, and bikes ridden hard break more often. Having said that, for most of us spending our vacations fixing our bikes rather than riding them isn't exactly what I'd consider fun, and there is nothing fun at all about fixing some mysterious bike part with numb fingers during a downpour on a highway shoulder.
So probably the first and most important principle is:
Fix everything that is broken or even might break before you go on tour. Broken things won't fix themselves on a long ride.
I make my bike perfect before going on a long tour. New tires, new chain, new brake pads, and possibly new brake rotors as well. Especially if you are starting out you want to stack the odds of a successful trip in your favor as much as possible, and an easy way to do that is to fix everything on your bike before you start your tour.
Even with all that, stuff is going to break. You are going to get flat tires, bolts work loose, mysterious little parts you never noticed fall off during bumpy descents. Stuff happens. So you want to have the resources to fix your bike and keep your trip going, or at least McGyver your bike enough to get to the next town.
The absolute bare minimum stuff I bring on any trip, no matter how short, is:
There is quite an assortment of other stuff that, while not strictly necessary from a survival standpoint, makes things much easier and can save you quite a bit of time and grief on the road:
Now for the commentary:
The Blackburn Wayside is a great multi-tool, especially in the sense that it is very large. It has some things you don't often see on other multi-tools, like an 8mm hex key, a chain tool, spoke wrenches, and valve core removers. If your multi-tool doesn't have those things I'd seriously consider bringing them. They do sell these cute little caps that convert a 6mm hex key to an 8mm.
The tire levers I carry also double as quick-link removal pliers. If you aren't using a chain you can safely just use regular tire levers.
The Lezyne pump is an awesome pump (and awesomely expensive as well). One downside is that it has a propensity to unscrew Presta valve cores if they aren't tight. If you use a pump like that make sure to bring a valve core tool and possibly some Loctite. One reason I carry a Presta to Schrader converter is that combination is less unlikely to unscrew Presta valve cores.
I don't carry CO2 cartridges and a crack pipe. Largely because while they can get your tires inflated more quickly, replacing CO2 on journey is problematic at best so you still need that pump. Also, if you are like me and drop the tire pressure when riding on soft surfaces you will quickly run out of CO2.
Yes, you can go tubeless. You end up carrying approximately the same stuff -- pump, patch kit, spare tube, and tire boot.
A lot of this stuff won't do you a bit of good unless you know how to fix your bike. While I've seen people bleed hydraulic disk brakes in a trailhead parking lot, and a friend of mine managed to repack rear wheel bearings in a campground, a lot of repairs on modern bikes, electric or not, are much more easily done in a shop or at least your garage than on journey. So again, prevention is a wise choice.
- Tire Levers
- Patch Kit
Amazon.com: Rema Tip Top Patch Kit / Large (TT 02) : Health & Household
Buy Rema Tip Top Patch Kit / Large (TT 02): Braces, Splints & Supports - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com - Multi-Tool
Amazon.com : Blackburn Wayside 19 Function Bike Multi-Tool (Outpost Pewter, One Size) : Sports & Outdoors
Amazon.com : Blackburn Wayside 19 Function Bike Multi-Tool (Outpost Pewter, One Size) : Sports & Outdoorswww.amazon.com - Mini Wrench/Pliers
- Mini Pump
International update | Chain Reaction
An information update for customers outside the UK.www.chainreactioncycles.com
- Small Locking-Blade Knife
- Duct tape wrapped around the pump
- Rubber bands holding the tire levers together
- Tire pressure gauge (I tend to find the on-pump gauges insufficiently accurate)
- Spare tubes
- Tire boot (Canadian $5 bill works best for me)
- Spare valve cores (less necessary if you have more than one spare tube)
- Spare rack and fender bolts
- Chain lube (it is reasonable to reapply every 75-100 miles)
- Fiberfix spoke or spare spokes
- Spare brake pads (only really useful if you know how to work on brakes)
- Spare chain links or quick links (make sure they match the size of your chain!)
- Presta to Schrader valve converter (see notes below)
- A tube of grease
- Old toothbrush or pipe cleaners
- Marker (Silver Sharpies are best) to mark holes in inner tubes
- Cable ties
- More duct tape
- Electrical tape
- Loctite
- Crazy glue
- Shop towels and handy wipes (you can replace shop towels on journey by grabbing the blue paper towels at gas stations)
- Nitrile or latex gloves
