I thought I would share this tip because it’s useful when buying a second hand bike. It applies to the frame battery of the PW series drives.
By pressing down the button on the battery for a given amount of time, you can obtain information about:
The leds are assigned numbers in the following order:
4 ---- (F)
3 ---
2 --
1 - (E)
Press the button on your battery for 20 seconds. The following led combinations give you the number of cycles:
Led 1 Blinking: 0 to 100 cycles
Led 1 On: 101 to 200 cycles
Led 1, 2 Blinking: 201 to 300 cycles
Led 1, 2 On: 301 to 400 cycles
Led 1, 2, 3 Blinking: 401 to 500 cycles
Led 1, 2, 3 On: 501 to 600 cycles
Led 1, 2, 3, 4 Blinking: 601 to 700 cycles
Let 1, 2, 3, 4 On: 701 or more cycles
Note: A new battery should only have led 1 blinking.
Determining the absolute battery capacity
The leds are ordered in the same manner as for the previous test.
Press the button on your battery for 30 seconds. The following led combinations give you the absolute capacity:
Led 1 on: 0 to 24 % capacity
Led 1, 2 on: 25% to 49% capacity
Led 1, 2, 3 on: 50 to 74% capacity
Led 1, 2, 3, 4 on: 75 to 100% capacity
Note: A new battery should have all 4 leds turned on.
- The number of cycles: this tells you how many times the battery has been fully charged.
- The absolute battery capacity: tells you how much energy storage capacity the battery has lost since it was new. A new battery has an absolute battery capacity of 100%, whereas a battery that has lost 26% of its energy capacity will have an absolute battery capacity of 74%. The absolute battery capacity is expressed in 25% increments.
4 ---- (F)
3 ---
2 --
1 - (E)
