Stromer Antwerp bags??
MinnBobber
Antwerp bags reviews
How is that working out?
It looks like it mounts to stock rack and another side bike member, without needing a side additional framework….
Is it very soft sided or mostly rigid bag?
Any pictures?
Is it a solid secure mount?
Where does it attach on the side of the rear wheel?
Any rubbing of paint/ advisable to add protective clear wrap to any areas?
Thanks for any comments.
P.S.
Stromer Trunk- is that much more solid sides vs Antwerp?
Likely buying ST5 and looking at what accessories to add.
Thanks for sharing your opinion.
MinnBobber
Hello,
I do use this bad everyday and it is the best I have: light and solid.
He has the back rigid (wheel side) and the bottom rigid. The rest is soft.
The fixation done directly on the rack without any additional framework.
You’re right, on the long term it will scratch the rack and the frame.
I have added some clear protect for the frame and special rack accessories from tubus.
I will send you some pictures.
As promise the accessories:
