Well, here's a homemade charger you could build for about $25-30 if you can scrounge a few bits:
DC to DC boost regulator CC/CV (18-35$)
old PC power supply (0-25$)
4.7 ohm 10w resistor (2-5$)
14 guage wire
plug for charge port (rca fits most batteries)
This is about as simple as you can get. Old PC power supplies are basically free, 250-350w is adequate... anything that is rated 20 amps at 12v. The 10w resister is for the 5v rail (expect it to get warm/hot = normal). 12v out goes to DC-DC regulator input. I suggest a boost regulator with a numeric display, 10a+ rated, and output up to ~90v so you can charge any battery. (search the bay for "converter step-up 90v" and look for one with a display). Reg output wire should be long enough to conveniently reach the bike.
I added xt90 plugs to match my bike power leads so I can swap in my watt meter to see how much it takes to charge up the battery or an adaptor for my 12v motorcycle battery. I repurposed an ancient ide disk drive tower for a case... you could certainly make something prettier. 10a@12v gives me a little over [email protected] (~85% for my 48v battery). It basically stops charging when it reaches the set voltage, but may overshoot a small amount if you leave it for days. Voltage matches the meter pretty closely.
14 guage wire
