ST1 Elite grips were terrible - changed up to Ergon GP1 large. Huge difference. Hands don't get numb right away. Still need to move my position around a bit while riding, but they aren't near as bad.
stock handlebar was 685mm and the steering felt twitchy. - changed up to a 760mm wide, 9 deg back sweep, 31,8 dia at the stem, 20mm rise. That small change is notably more stable, and just feels like it should be. If they had it in stock I'd likely have gone for a 40mm rise - happy with the new bar as is though.
stock Wellgo non-sealed bearing pedals are rough and a bit small. - changed up to Shimano Saints. Feet fit the pedals better. Bit more comfortable. Cant say I notice the smoothness, though its quite obvious spinning by hand. Tried SPDs before and had too many close calls getting back out. Sticking with flats. All my commutes under 10km though.
thinking of a 9 speed XT shifter for lighter effort and better feel. Will order through chainreaction. Local dealer is about twice the price.
Axiom Seymore paniers - fit the rack nicely, snap on, no interference with peddling.
Blinky light for seat stem
Likely going with Arbus folding lock as it has a water bottle mount to store it.
Doesn't appear to be any locks on the market the pros cant get through quick with a cordless angle grinder.
If Litelok was available here I'd give that a try. Still researching. Anything is just enough for an 'honest' person to pass on it.
(edit ... picked up the Arbus. Harder to cut with bolt cutters, but none are resistant to angle grinder. Main benefit was mounting it on the water bottle boss for easy access/storage)
