Yes exactly. A guess 😉 . I think the only thing that would convince me either way is a good Solidworks simulation or actual 🚴 testing.
I can visualize processes in my mind pretty well :)
(Each of these two suspension pieces requires a rigid anchor at either side to work).
I have to argue against all this shock absorption. I like to lift my bike front tire and drop it an inch to see it bounce a bit. That means it's light weight bike to me. And non-shock bikes are more like the bike I rode as a kid - nothing fancy, all arms. Heavy bikes are plushy. The SL is a stallion. Ride accordingly. 😄
LOL The vado is the stallion . The Sl is the young male horse who herds together with other non full power horses . It's fast colt but doesn't have the stamina it's father does .
Hi, The MSRP I paid through Specialized was actually a bit cheaper than an LBS authorized dealer because Specialized picked up the tab for road sticker registration.
HUGE difference between 5.0 and 4.0!
FutureShock + Carbon Fork
12 speed vs 10 speed
Deore XT vs Deore Shifter and Derailleur
Higher grade cassette
Shimano Chain
Carbon seatpost (EQ only)
Better rims
Higher spec Tektro brakes
Higher spec headlight
Higher spec saddle
5 cassette is 10-45t vs 4 cassette at 11-42t. 5 is faster by a bit and a bit more torque on a given grade at a given cadence. Doesn’t seem like a huge difference until you’re passing up a rider on a 4 🤣
In my opinion it’s an entirely different bike and great value. You can compare side by side on the website:
There is a detailed document describing max loads on the bike, also one specific to child carriers. I will look today. Note the carrier is a bit special because it’s integrated with the fenders on the EQ version. I’m not sure you’d need to change the rack though - it’s racktime compatible btw. Also rear wheel cargo limit is 55lbs/25kg.
Update: @aj1 - OK I had a look at the child seat addendum. Basically it’s a few warnings and disclaimers saying legally the bike was designed for one person and you assume all the risk. Also apparently the carrier/rear rack can carry 25 kg max rated. So really it’s just a matter of how you would go about mounting the child carrier.
I’m still deciding between the Vado SL 4 bs 5 goes
I’m still deciding between the Vado 4 vs 5 and have a few questions:
It sounds like the 4.0 with the addition of a shockstop stem cancels the benefit of the 5’s future shock. The main difference I see besides the front end is the group set. I’m familiar with road bike group sets 105, ultegra and dura ace, but not so much with the gravel/mt. Bike sets. Can someone tell me the differences between the Deore and SLX? I know the 5.0 has two more cogs but is there a noticeable jump up in shifting quality?
Specialized confirmed that none of the US Vado SL models have a carbon seatpost (the US web description has a typo), so no difference there. The wheel descriptions are different but vague. The few other differences seem pretty insignificant.
I’d like to hear about the slx groupset difference, if the stopshock stem really does the job, or anything else I am missing.
thanks!
thanks!
Price difference in Japan was only 25% premium, and then this 5 was the only bike available. Honestly if I had to choose and had a choice between a 4 or a 5 I might as easily taken the 4. All of the differences are minor in comparison to the major things that it has in common. For me the biggest advantage of the bike was the weight, the other day when I returned from the bike shop I was most happy with the fact I could load it and unload it from the roof of my car. That’s a MAJOR advantage, that I couldn’t get with any other bike in the price class of even the 4. If you get the 4, I would suggest strongly considering the EQ. That’s fantastic value. Whatever your decision don’t park on it and dither - Specialized told me there are none available in Japan or Asia until 2022.
As I indeed have experience with Deore (10sp), SLX (11sp), and Deore XT (12sp), I think I can answer your question.
As I am a person paranoiac about the cadence, I'd be more happy with the 12-speed. Still, I have accepted the 10-speed and am happy to think of how less I will pay for the new chain, and later, the new cassette :)
More important is EQ or non-EQ. If you plan riding in forests a lot, I recommend the non-EQ. DryTech fenders are excellent but a small stick can get between the fender and tyre, block it, and do some damage (I actually have experienced that!). On the other hand, the non-EQ with its saddle integrated tail-light makes it hard to replace, say, the saddle or the seat-post. Decisions, decisions...
Having said all the above, the best advice I can give is: Select the bike by colour you love. That will be something you will see every single day. And that is something you cannot change later. Honestly!
The 5.0 wheels are tubeless ready. I switched my Vado 5.0 EQ over to tubeless. The 4.0 wheels are not compatible. The 12 speed is well worth the upgrade to me. You have higher top end and a lower granny gear. If you have hills, you’ll appreciate riding up instead of bailing out and pushing. Totally depends on you and the hill, but lower gears are always appreciated.
Stefan That table is backwards. The 10 speed should read “Shimano Deore, 10spd, 11-42t”. You’ve got it listed as 10-45t.
The Vado 5.0 is “Shimano SLX, Hyperglide+, 12-speed, 10-45t.” You’ve got it listed as 11-42.
I beg to differ on maintenance costs as well. If you want to see “high” costs, buy a SRAM Red or Shimano Dura Ace drivetrain. They’re not really expensive, but they do define high for the category.
That is a very personal choice. You either love or hate the tubeless. No other way :)
I have compared gear-inches on both systems and the difference is very small. Neither of the drive-trains here is even close to the MTB 20 gear-inches. Replacing the chainring with the 38T gives far more.
Going tubeless is a personal choice. Having that choice is not. If you buy the 4.0, you have no choice. Reminds me of Nietzsche. He walks into a café and orders a cup of coffee, no cream. The waitress says, I’m sorry, we’re out of cream. Would you like it without milk instead?
I’ve ridden them. I have a 10-50 cassette on both my Creo and my Salsa Warroad. I ride through those gears all the time. The bigger the gear, the easier it gets. A 38t chainring would just amplify the difference. I’ve tried that too: 38, 42, and 46t chainrings. Calculators don’t measure the reality of the mountain. You’re a flatlander, so I understand it isn’t a big concern for you. If you deal with hills then the lower gearing is a big deal. That Vado 5.0 45t bailout gear is pretty generous. With a motor, that may be all a climber needs.
Twenty gear inches is very low. It isn’t really necessary unless you’re going fully loaded bikepacking. I think my Warroad is around 22.8 gear inches. That’s also very low also especially for an unladen 18 lb bike. But horses for courses as they say. I ride in the mountains and when I’m in that 50t gear, I’m sure glad it’s there.
Rincon, please listen to me.
There are two figures:
  • 16400
  • 21500
What in the world should be included in an e-bike to justify the 5100 difference?! I would understand another motor. Bigger battery. But a few insignificant components for 5100 (31%) more?! How much would two tubeless rims cost (including wheel rebuild) to justify such big price difference?
The money saved on the lower version is a lot of money for the upgrades you really need. Range Extender was the first on the upgrade list.
Will you agree with me that 50T granny cog is far more than the 45? I had 51T on my Trance E+. And 38T as the chainring.
51/38 is a whopper! I can’t imagine needing that on an ebike even if you’re climbing Mt. Fuji.
Yeah, 50t is a big improvement over 45t. I happily upgraded to a 10-50 cassette from a 10-42. I only get to the 50t cog when I shift through all of the other gears. It is definitely a bailout gear. I rarely need it on the ebike. The next lowest is a 42t. I think if I had a 10-45 cassette it would be just about perfect. A 45t granny gear would get more use than the 50t, on an ebike. On the Warroad the 50t gear is a necessity.
