Specialized Turbo Vado/Como/Tero/Tero X User Club
Stephan does this help?
Almost ;) Not only is the product only available in the U.S. (and overseas shipment is not feasible now) but the Specialized thru-axle has also a "specialised" head... I will tell you what the problem is. As the Specialized axle is made of aluminium, the head socket has worn out. Before it was too late, my brother took it out, then threaded the socket, and finally locked (with Loctite Red) an external screw (having a larger hex socket) in the new thread. If that cures well and the axle can be fastened and then removed from the fork, the problem is solved. If not, I'll have to order from Specialized, and I am afraid of the part unavailability, because that's Ye Goode Ole Specialized...
Ye Ole Goode Specialized...
What's gone wrong with your axle?
My Vado 5 has a front 15mm axle, but it also has a suspension fork. Stefan, I suspect your axle is a 12mm as you have a rigid fork. These aren't available from any of the Euro online bike shops?
In the States the Robert Axle Project at https://robertaxleproject.com/ is a popular source for all things related to through axles. I'd always start with them.
I've just explained the problem above, O Tim from Sierra Nevada! ;)
P.S. Available 12x100 mm axles have the 1.5 mm thread while I need 1 mm...
Saw your post with the explanation after my post went up...😖
I used the Axle Finder page at https://robertaxleproject.com/product/lightning-bolt-on-axle-front-12-mm-x-117-mm-x-1-0-thread/ . Their 12x100 1.0 pitch axle is $42 + shipping I assume. Their support email has been helpful for me in the past.
Hope this helps.
@Stefan Mikes is taking his front wheel out frequently for transport and the Specialized axle quits this. Other users reported similar problem.
Axles from Robert Axle Project are common even here if you're looking for towing solutions or upgrading.
If they confirm this
suits Stefans Vado I would go for it.
Their shipping to Poland is ~$20 for the 12x100 1.0 pitch axle.
My sons use their axles for towing trailers to help with local MTb trail maintenance.
This source in Germany
has it available for 43€ + 10€ shipping to PL, and no duty hassle.
Thank you! Thank you very much!
The price doesn't matter. There are problems with overseas shipment nowadays but purchase from Germany is easy!
Anyone got any information on how to de-restrict my Vado 5.0 in the UK please?
You need access to the Specialized hardware and software that is used for programming. This is only available through dealers. I've read posts that report good results with a hardware replacement for the speed sensor magnet. Try the Search function for this.
Mark has just ordered the Planet3. I've heard that works nicely.
So I just picked up my Vado 4.0 LTD from the LBS yesterday. The yellow one with the "suspension" seatpost and 50's on the rims. Here are a couple of thoughts in no particular order:
I ordered on June 5th from Specialized and the bike was ready in Boulder, CO at the LBS on the 15th. Not bad, considering.
I will need to get at least the 44 or the 48-tooth front ring. I spend a majority of time on the 11 or 12 rear cog and find myself spinning at or above 28mph (I ride a lot acoustically, and I live in an area with a lot of hills).
The ride is comfortable. There are a *lot* of the chip&seal cracks around my neighborhood streets and on my carbon gravel bike those can be brutal. I really almost didn't even notice them on this bike. I haven't adjusted anything on the bike yet except for seat height and different pedals.
I tried the Mission Control "Smart Control" on my commute route and thought I put in the correct parameters. It seemed to do okay except for the big hill I start out on. It's about 1/2 mile long and about 11% grade. The Smart Control kept my power fairly limited so I was having to continuously switch to "Turbo" mode. Then it would switch back to "Smart" after about 10-20 seconds. So I kept that up until the top. There may be a way around that but it didn't jump out at me.
The bike seems very stable. I had it up to 38mph or so on some downhill sections without a wobble or feeling out of control at any time. The brakes seemed responsive enough, if not super tight. I got used to them pretty quick.
So far (24 hours and two rides) I'm enjoying the bike and it seems to be delivering on what I expected from it. A straight-forward commuter with the ability to get to work and back without breaking a sweat...and in my community, that's a big deal.
The color is more muted than I expected. It's more of a "flat mustard" then anything else. Which is fine. It is more "visible" than either grey or black, so that's okay.
I do like the color...😎
Ride it a few more days and decide on the front chainring...I have a 48t on my Como that I want to switch to a 40t or 44t for hills. A swap maybe? Going 38 mph on a bike! I grab for brakes at 20 to 25 mph...
