sfebiker
Hello,
I need to install a shorter stem with higher angle than the stock 70mm one.
Does anyone know what the correct partnumber for the shim that allows 1 1/8" stems to be used on the Future shock 2.0 on the Creo SL?
I've found this one online and want to verify it is correct.
mikesbikes.com
Specialized partnumber on this site is S204800001
I also see this one online that is partnumber S174800001
www.amaincycling.com
Which is correct?
Thanks in advance!
Stem Shim for Future Shock: 22mm ID x 24.65mm OD
Shim for mounting S-Works Future Stem on pre-2020 Specialized Future Shock 22mm ID x 24.65 OD Shim Where is this product used: Model Year Category Model 2021 CREO SL CREO SL COMP CARBON 2021 CREO SL CREO SL COMP CARBON EVO 2021 CREO SL CREO SL EXPERT CARBON 2021 CREO SL CREO SL EXPERT CARBON...
Specialized Roubaix/Ruby Stem Shim (Black)
This is a stem shim for the following Specialized bikes: 2019 Diverge S-Works Frameset 2019 Diverge Men Base 2019 Diverge Men Comp 2019 Diverge... S174800001
Which is correct?
Thanks in advance!
