Specialized Como 2.0 or Civia Parkway
Advanced thanks for your input. I've narrowed down my choice to these two. But I'm open to ideas! I am in my early 60s and could lose some weight. Both bikes feel good as I like the upright feel and they look good. I will be using it for fun and fitness. The cost is more than I am comfortable spending but I want to get a bike ar my LBS for service and pre-rides. What do y'all think???
Comparing specs the Civia is about 5lb lighter, has smaller 26” wheels compared with the 27.5” wheels on the Como, a smaller battery 400wh v 460wh, a weaker motor 40nm v 90nm torque, manual v hydraulic disk brakes. It would be good to test ride both, but if you ride up and down hills I would suggest going with the Como. Also I understand the Specialized mission control app helps you calculate a reserve battery percentage on longer rides which might tip the balance if you’re thinking of touring.
