lewes5
After suffering 3 flat tires over about a six week period with the Trigger Sport tire and tube on my Vado 3, , I decided to swap out the tube and tire. This is a course I have biked on my old Trek for about 4 years without an issue. Neither the I or the LBS could find what was causing the hole in the tubes - we both examined the wheel and the tire closely after each flat but could find nothing that was causing the puncture.
So, I decided to simply purchase a new Schwalbe tire, the same size (47-622) as the Trigger. I was surprised to find the Schwalbe was narrower than the Trigger and the sidewall not as high.
Although it went on the rim, it simply looks like a smaller tire.
Anyone else have a similar experience with the Schwalbe tires? Will this this smaller tire cause problems. Its on the front, so I expect to show slightly higher speeds on the speedo.
Thanks much!
chuck
Thanks much!
chuck
