I find I use gear 6 for take off and cruise in 11 on level ground. The ratio between the gears is close and find that on flat ground - 6,8,10,11 is all you would really need. 11+ for downhill.
I am so jealous you have the HS. If only we could get that here..... legally.Having the plain ole manual shift Rohloff I've made almost the same observation on my commutes. I have the HS version (28 MPH) bike so I frequently use and bottom out the 14:th gear. But I seldom use anything below 6:th gear even if some steep forrest trails offer possibilities. Rohloff could make a 6 or 7 speed hub with the same bulletproof build quality, it would suite e-bikes better and hopefully be a bit cheaper.
I read somewhere that the E-14/Bosch motor has built-in shift detection so that when you press a shift button, it automatically backs off before shifting so that the rider doesn't have to. Since a shift takes only 180ms, it should hardly be noticeable. Is this not true, are you not seeing this?I've had the E-14 now for 3 weeks. Using for commute on cycle paths & roads. I find I use gear 6 for take off and cruise in 11 on level ground. The ratio between the gears is close and find that on flat ground - 6,8,10,11 is all you would really need. 11+ for downhill. Haven't found a hill yet where below 6 and turbo was needed.
Shifting is mostly quick. A little of bit of learning to back off pressure when shifting up gears under load. The shifter buttons are a tad small in my opinion. I also question if they will last more than a couple of years with frequent use.
Love the auto downshift on stop function.
Yes it does do that, and its hardly noticeable on level surface, however when accelerating up a hill I find I still have to back off a little.I read somewhere that the E-14/Bosch motor has built-in shift detection so that when you press a shift button, it automatically backs off before shifting so that the rider doesn't have to. Since a shift takes only 180ms, it should hardly be noticeable. Is this not true, are you not seeing this?
Has anyone here considered replacing the controller buttons for the E14 shifter? I find them very hard to use (normal human hand) and I want to replace mine when it arrives.
I agree the shift buttons are terrible. I contacted Rohloff tech support. They responded by saying there is another shifter in development, but wouldn't commit to a release date.Yeah, anyone?
I have one of those on my bike. It puts the buttons in a very convenient position.That's fantastic news.
I've been considering this-
E14 TRIGGER ADAPTER, 75,99 €
Montageaufnahme: Magura Bremshebel (rechts) der MT Serie Material: Aluminium (CNC-gefertigt) Mit dem NICOLAI E14 Adapter veränderst du die Position des Rohlwww.nicolai-bicycles.com
Thanks for the info; I see where that might help with position The problem I'm having, and what you described, is that the buttons are too hard to push. I have several hundred miles on the bike and the buttons have not broken in or gotten any easier to use. In the attached photos you can see there is a micro switch located under the rubber shift button. On the back side of the rubber button is a nub which is supposed to align with the switch. As we know it does a lousy job of actuating the switch for several reasons: the button is too soft, the wrong shape, aligns poorly with micro switch, and the embossed arrow irritates your finger after repeated use. Also, 50% the rubber outer switch is above the micro switch, so there is a region of the button where pushing does not effect a shift at all since it is not aligned with the micro switch. Other than that its perfect haha. A hard plastic button would probably work better since it could supply more force directly to the switch. If I was a 3D printer guy, I'd try to make one.That's fantastic news.
