Hey folks…we have two RadRover fat tire bikes that we need to haul on our truck that has a slide in camper. Being able to swing the rack out of the way was the most important feature to us, since the access to the camper is (only) in the rear. We also needed something that would make it a easier to load -- compared to the "challenging" hanging rack we had. We found the right rack, so sharing info in case others are in the same boat.
The BackStage 2 is a slick platform-style mount. It snugly holds two bikes (up to 60lb. each). You can swing the loaded carrier away from the back of your vehicle and off to the side to access your hatchback/camper/van etc.). Brilliant!
What I really love about this is that it came with everything needed to take care of two fat tire bikes…didn’t have to buy any extenders or anything.
The rack also tilts 30 degrees (easily) for quick access to the back. Came with hitch pin lock and integrated cable lock that is is a deterrent, though not much more.
Caveats: two bikes max. 2” receivers only. Assembly instructions were lacking - though it wasn't overly difficult.
Check it out if need this type of rack…we are really happy to have found it and recommend it.
https://rockymounts.com/collections...ucts/backstage-swing-away-platform-hitch-rack
