Gionnirocket
- USA
- City
- Y. O.
Odd situation... Or I'm just clueless on this.
Purchased a new seatpost mounted rack and I wanted to check clearance with the rear suspension so I let the air out of my rear shock.
Looked good so I put back the 160 psi that was in there.
On my first ride about 10 mi in I herd a little tire rub and on inspection the rack was on the fender and the shock was depressed. I tried adding some air and went up to 250 psi and got some clearance so I locked the shock in that position and finished my ride.
This morning the shock was fully extended so I checked pressure and it was holding at 250 psi so I left the pressure as is but unlocked the shock so I'd have some suspension.
On today's ride the same thing happened about six miles in so I messed with the pressure until I got some clearance and then locked the shock again and made it home.
So once home I started from scratch and set both the rebound and lock fully counter clockwise and open. Bled all the air and then proceeded to add 150 psi. Exercised the shock 5 times to equalize and then checked pressure again. Holding a 150 psi but it wasn't fully extended so again I went up to 250 psi and still not fully extended...
So is my shock busted or am I?
