Removing a Shimano Steps E6000 right side crank.
Hello!
I am attempting to install an on bike charging port/battery mount on my E6000 equipped bike. The left non-drive side looks conventional. The drive side looks convenny until I lift the crank. Then there is a nut that must be removed to drop the motor cover. Motor cover needs to be removed to route/access the cable port.
You need a special tool to fit the Shimano lock ring... see below.
