Reention Dorado 17ah 48v charger led goes green always:
I am new here, and looking for experties. After reading some forum the first diagnostic was the fuse. I open the battery case and unfortunatly, in my Dorado reention 48v 17ah is no fuse. I went to the next mess during open the case and pull up the cells. I found two free cables and don't know where should be connected?
Next question: I ordered a BMS 13s 48v 35a and replaced it with original BMS 13s 48v 45a unfortunatly, the result is the same the charger will not charge the battry and the green led switches on as soon as I push in AC.
When I measure the charger or discharger both have same voltage currently 46v. As soon as I push the charger in AC and measure the charger the multimeter showes 54v.
I would welcome any advice would rescue the battery. Thank in Advance
