Fofer
Let's talk about compatible rear racks for the RadRover. I've done some searches online and have seen folks asking, without getting specific answers. The RadRover's lack of pre-drilled mounting holes or brazeons makes it a bit trickier. Rad Power posted a video of the "BlackBurn Outpost" rack, but I don't really like the look of it. My seat is set pretty low, which means I don't have enough room for the clamp of a rear post-mounted rack.
Instead I installed the Ibera IB-RA5 (which works with disk brakes, and is the same rack system I have on my other eBike, so the clip-on bag I use is interchangeable.)
For mounting this rack, I replaced the seat clamp with the Sunlite Alloy Seatpost Clamp Rack Mount. I also used the Portland Design Works P-Mounts to secure it to the seatstay. It's working great so far. I especially like this rack because it has a lower shelf that's a good spot to store my lock when riding.
See pics below:
(I'll obviously use bungee cords to secure this lock if I ride this way)
(This big Utility lock wedges in there perfectly!)
I like the look, feel and utility of this rear rack solution so I figured I'd share. Thanks for all the great info, gang! What rack solutions have you found?
Loving this eBike. Thank you RadPower!
See pics below:
![Monosnap_2015-10-23_12-22-48.png](http://www.fofer.com/sharedimages/Monosnap_2015-10-23_12-22-48.png)
![Monosnap_2015-10-23_10-28-20.png](http://www.fofer.com/sharedimages/Monosnap_2015-10-23_10-28-20.png)
![Monosnap_2015-10-23_10-28-50.png](http://www.fofer.com/sharedimages/Monosnap_2015-10-23_10-28-50.png)
![Monosnap_2015-10-23_10-29-19.png](http://www.fofer.com/sharedimages/Monosnap_2015-10-23_10-29-19.png)
![Monosnap_2015-10-23_10-29-50.png](http://www.fofer.com/sharedimages/Monosnap_2015-10-23_10-29-50.png)
![Monosnap_2015-10-23_10-30-32.png](http://www.fofer.com/sharedimages/Monosnap_2015-10-23_10-30-32.png)
![Monosnap_2015-10-23_12-19-35.png](http://www.fofer.com/sharedimages/Monosnap_2015-10-23_12-19-35.png)
