bazzapage
The problem with the rear disc mounts on the legacy Turbo's is that the screws are a bit short, and can get wiggly over time ultimately stripping the threads. You can feel this as play in the system if you grip the rear brakes and rock the bike backwards and forwards.
Q: Has anyone found a permanent engineering solution to this?
[I have used a thread repair epoxy which doesn't seem to last either, and now have tried glueing the disk to the hub in addition to take out some of the shear forces. Is holding after two rides. But obviously I'd prefer something a bit more robust.]
