6zfshdb
- USA
- City
- Northeast Pennsylvania
Being a heavy rider, I've always been concerned about the weight carrying capacity of the bikes I've owned over the years. It was a major factor in choosing an ebike.
I understand that spoke gauge, number of spokes (usually 28, 32 or 36), spoke material, spoke angle & bracing if any, rim material & design and tire size are all contributing factors to the weight carrying capacity of a bicycle wheel. The total weight can't simply be divided by 2 since the rear wheel on most bikes carries more weight than the front. In addition to wheels, frame material & design are also major factors.
What I don't understand is how a cheap Chinese Walmart ebike with 32 - 14 gauge spokes can claim the same weight capacity as an expensive model with 36 - 12 gauge spokes. Yes, the Chinese could be (and probably are) over specking their bikes but I would think complaints and lawsuits due to failures would cause Walmart to remedy this situation. I suspect that most quality ebikes are under specked to a certain extent but not enough to account for this difference.
Walmart is just one of the weight rating discrepancies I've noticed when looking at ebikes. It also exists when comparing major brands. The weight ratings for most major manufacturers range from 250# to 375# yet the above mentioned specs are often quite similar. Some brands, like Pedego, offer mag wheel options which increase the capacity to 400#. That would indicate the weak link is the wheel.
Am I missing something here? Why is there such a big discrepancy in ebike weight capacity?
