mrgold35
- USA
- City
- ABQ, New Mexico
I noticed my battery isn't charging when I plug in the charger. I still have power to the Radrover when riding and the hub motor and LCD works as normal. The power buttons on the handle bars and battery pack works as normal. No error codes on the LCD display. I have two chargers and I've tried both and the green light on both chargers stay on as if the RR is fully charged (the other light doesn't go to red when charging a low battery).
When riding, the LCD shows the ever lowing battery level correctly (down to 1-2 bars); but, the battery meter on the side of the battery shows a full charge every time when I check. I checked the 30 amp fuse and it is good. I keep my Radrovers in the garage and the temps are usually +55 degrees.
I haven't check my other RR to see if it is having the same issue (that battery is already fully charged). Is there anything I'm missing? Is there a battery reset? Seems like the battery thinks is is fully charge and it is not taking any more power?
