Do you have the controller set for 40 kph?
It comes with 32kph. The drag might improve at 40. The wind resistance is the biggest issue I see with speeds over 19 mph. Why are you reluctant to use PAS 3? With a 12 mile one way commute you should be able to use all the power you want and still recharge every other day.
Sounds like you like to go fast. A 46 tooth is probably what you need.
