IggyBBR
- USA
Will unbolting the Bosch CX from the frame void my warranty from Bulls? Thoughts...
______________
Recently purchased some 4 pot disc brakes, to replace the 2 pot brakes that came with the bike. I thought I could do a simple swap of the calipers and lever without having to reroute the new brake hose internally. The Shimano Zee uses banjo fittings, while the BR-M615 uses a hose connector. So apparently the brake hose is routed in-between the frame and motor and the only way I can get to the cable is by loosening or removing the motor.
______________
