vincent
this is kind of a long story
the cemoto full suspension mtn bike from electrobikeworld was the first bike i bought about a year ago
i had not been on a bike in 30 years and it seemed way too fast for me , and the pas seemed way too powerful
think this is a cadence sensor pas, it has a 5 magnet disc
it is a 36volt 8.8? battery with 350 watt motor i think
has one speed pas with a 5 magnet disc and throttle with override
anyway right after i got it took it to a guy that does some ebike work in tucson and he took 2 magnets out of the disc trying to slow the motor down for me
with these 2 magnets out is pretty much the only way i have ridden it since i got it
at first i wasnt sure how much it changed but as i rode more it seemed ok, but it was surgy
looking back would guess i had 30-50% pas this way and a good jump forward using the throttle override when i wanted to
would easily get 30-35 even 40 miles out of a battery
rode it some but not a lot, but i did get more comfortable with the bike, higher speeds etc
in the meantime i have learned more and wondered if my inconsistent cadence was causing that surging? now my cadence is much better....
anyway decided i should fix the magnet disc hoping the surge would go away and thinking i am fine now with a faster bike etc, should be better right....
got a couple of similar size ones with 5 magnets off ebay, seems like they were 2.55 and 2.65 sizes
we matched the disc that was in it and the LBS put the new 5 magnet in a week ago
rode the bike once and thought it was way faster, a little too much pas but still pedalling in 5-6 i had good resistance and the bike was doing 15mph easily, it was ok
just thought it was a little faster and i was ok with that , was still pedalling hard and getting a good workout, just kind of fast
but i burned up way more of the battery than usual, like double
tonite i tried to ride it and the pas is 100% on, in the flats could not keep any resistance on the pedals at all in any gear and the throttle overrride had nothing, the motor was wide open as soon as i barely pushed the pedals
rode with no electric for a while, then stopped to see if i could adjust the sensor
found that the disc is just riding on that spindle and i could move it in/out and this would affect the pas
stopped several times and adjusted it, moving it slightly away from the sensor slowed down the pas some
but it was up and down, 3 minutes with some assist but then it would cut out for a minute or 2 completely and then come back
move the disc in a little more and get more pas, too much really
could not find a perfect spot and no mater what eventually it is going to move some i would think because it is just riding on that spindle..
questions are this
is this how this simple 1 level pas is supposed to work? wide open power? it seems the assist should be maybe 50% and then the throttle would override and take you to 100%
to me it seems this is malfunctioning??
or is it that the disc is not set right location wise and that it needs some kind of stop to keep it in place?
or if this is correct is the only solution removing a couple of magnets again?
any thoughts on all this would be great
cemoto713 hope you chime in and let me know if your pas works wide open like that with zero left in the throttle? or if yours acts different
i need this bike some when friends ride with me, most of the time i will ride this bike and they will ride the street or prodeco
so want to get it fixed even if i just have to take out some magnets
thanks for any help!!!
questions are this
