spokewrench
- USA
A compressor tank with less than 100% relative humidity would be unusual. Suppose ambient pressure is 15 psi. If I charge my compressor tank to 150 above the ambient, the absolute pressure is 10 + 1 atmospheres. The tank holds 11 time as much air as before it was pumped up. It won't hold 11 times as much water. At a given temperature, a space will hold only a certain pressure of water vapor.
At 25 C, the vapor pressure of water is about 0.5 PSI. That's how much water vapor a space can hold at 100% relative humidity. If the space is filled with air, approximately 1 molecule in 30 would be water vapor. If the shop is at 25 C and 50% humidity, the vapor pressure would be about 0.25 PSI and about 1 air molecule in 60 would be water. Compressing the air to 10 atmospheres above ambient, a total of 11, might increase the vapor pressure of the water content to 2.75 PSI. The tank could hold that at 60 C, but in my experience, the tank warms only slightly and soon cools.
If the tank sits at 25 C, its capacity will be 0.5 PSI of water vapor. The other 2.25 PSI, or 82% of what was pumped in, will condense and run to the bottom of the tank. If air from the tank expands to fill a tire at 45 PSI gauge, 60 PSI absolute, the vapor pressure in the tire will be .18, or 36% relative humidity.
If water can condense in air lines, it seems that in these cases, the pressure drop at the regulator is less than in my experience and the temperature drop is greater. I wish I understood the cause.
