I bought a milwaukee cordless tire inflator. Pretty sweet.
MILWAUKEE® Fastest 18V Cordless Tire Inflator delivers fast, accurate, easy inflation with the portability to take anywhere. Optimized for passenger, light truck, and other medium duty tires
www.milwaukeetool.com
Wow... $140 to $160 for the pump, and I'd need a $66 battery. Then I'd wonder when I'd need a new battery.
A hand pump that clipped to the frame was once enough for bicycles and motorcycles. At the farm in the 80s and 90s we used something like this.
3.7 CFM @ 90 PSI Belt Drive Air Compressor, Belt Driven Compressors, 3.7 CFM COMPRESSOR New, cast iron single cylinder single stage belt drive
www.surpluscenter.com
Maybe in the 1920s, my grandfather had mounted it on a board with a 1/4 hp motor and a handle. With that motor, it took several minutes to fill a 5-gallon tank, as I recall.
That tank had a ball chuck. So did my dial gauge. It was pretty quick to take the tank around, checking car, truck, motorcycle, tractor, bailer, and other tires. In town, with just a car and a mower, I'd use a hand pump. The hassle was repeatedly getting down to disconnect the pump and check with a gauge. For $10 I took a chance on an old Black and Decker compressor that was much smaller than the one at the farm but may have been just as fast, and it had a reasonably accurate dial gauge. To use it, though, I had run extension cords.
For $30 I bought a 12 volt programmable pump with a digital display. It plugged into a lighter socket. For $10 I bought an extender to clip to battery terminals. I considered that more reliable, and I could reach all the tires on the car. I could't unscrew the chuck without having a significant and unpredictable amount of air escape from the tire; so I spent $10 on a better chuck.
That's what I used when I got an ebike. The problem was that the bike needed air every time I turned around, it seemed, when I was about to ride. Unpacking 25 feet of wire, hooking it to a battery, and repacking afterwards were a hassle for a bike that frequently needed air. So I bought a 6-gallon pancake compressor, a 25-foot hose, and a digital inflator. The compressors I'd used had been left charged for convenience, but now I learned that this was hazardous. Under pressure, a tank would rust 10 times faster, then explode. To avoid that danger, I needed to switch it on and let it make noise for several minutes and park the bike where I could reach the side away from the brake disks with the hose. When I finished, I'd switch it off, pull the release valve (which made a very loud hiss), and as it hissed, reach down and unscrew the drain valve.
The clip-on chuck on the inflator was axial and too long to fit between the rear hub and valve. It was too long for the bowl hubs on my mower, too. So spent $10 on a brass ball chuck. A chuck like that was very convenient to give a shot of air to a tire on a vehicle that weighed a ton or more. A bicycle wheel, though, was likely to move when I pressed the chuck to seal against the valve. With the inflator, I'd have to maintain the seal with one hand while I used the other to hold the inflator for a reading, add or release air, and take another reading. Eventually, I replaced the ball chuck with one that had a clip. Now when it seals it stays sealed until I release the clip.
It saves effort to check all three ebikes together. I've been collecting data so I can fit it into a schedule instead of when the need becomes evident, just before a ride. I have been considering a cordless compressor small enough to carry in a coat pocket. No filling the compressor tank and fooling with the hose, and a pocket model might get me home in the event of a puncture. I bought a small manual pump, but I have trouble getting the chuck to seal.
