indianajo
Nice brakes.
The only thing I'd take apart is the front & rear axles to renew lube. Petroleum jelly works. Turn upside down & drip oil in the crank hole. Oil the head set while standing up. Oil all the cables while the exit is pointed up. Oil the shifter pivots. Oil the chain. Non detergent 5w oil, like type A or F transmission fluid, or 3 in 1 oil. NOT dexron ATF.
I don't know if trek has the easy stretch kiddie cables or the good ones like came on my yuba. Good cables don't stretch and require constant adjustment. Good SS slick coated cables can be bought from clarks & jaguar. I broke a shifter cable @ about 3000 miles.
I don't understand the passion for stands. I turn my bike over on handlebars & seat & it weighs 70 lb without panniers & tools. A display could be a problem, but I designed a standoff out of sheetmetal that could be unscrewed & turned down for turning bike over in 1 minute. I later deleted the display, it was wrong, 25% high in KM, showed 0 mph downhills, and fogged over from the rain. My throttle has voltage built into it now. That is all I need. I don't have to lift the whole bike If I'm just flipping it over. If you are out on road there is usually a tree, fence or telephone/cable generator to lean the bike against nearby. But this isn't Kansas.
If you maintain shimano 7 speed rear, understand they come unscrewed & drop balls after x000 miles. They are designed for kids that ride a bike 400 miles in their life. The ferrule against the internal race has to be discarded and a second 3/8"x26 tpi nut counter tightened against the race to prevent race from backing off. Stupid design. Wait til you've pushed the bike home. For me it was only four miles; lucky since I go 30 miles from home weekly. Balls are 1/4" BTW, even in this metric day. There is also an axle with a machined step from freethepeople but neither modernbike or thebikeshopstore ever stocked one. neither could get me 3/8"x26 tpi nuts either. The bikeshopstore shipped any size of random hex shaped junk instead of 3/8"x26 tpi nuts. They would give me my money back, but it didn't fix the bike. I bought another bike, until I found victornet.com had 3/8"x26 tpi taps, so I could make my own nuts.
The shimano 6 speed axle broke against my exhorbitant 180 lb. It is only 5/16" thick. Don't use one unless you weigh 120.
I'm using shimano 8 speed rear now, has gone 6000 miles without disassembly or failure. I have my Mac12 hubmotor on the front, as is the battery. I don't use it unless the wind is >12 mph or I'm out beyond 25 miles. When I'm in a hurry and do use it on the 80 hills of my route, it doesn't overheat. Total rise is 200', total weight is 330, of which I'm 160.
I can change the tube on the hub motor end in 40 minutes. Rear 30 minutes. I don't patch tubes, it doesn't work half the time. I don't unwire the motor to change the tube, just cut some ties & replace them. Pushing the bike 15 miles to destination or origin because it won't hold air is to be avoided. Been there, done that, when the first tube blew up immediately. Also when a used tire ripped the cord. I carry 2 cheap schwinn tubes and one jointed one which I've never used in 3 years.
