So was drew's hub bike a geared hub or direct drive?
It was geared, 500W.
The problem with throttles for offroad use is that the ebike would no longer be "Class 1," which on the few MTB trails that "allow" ebikes, are excluded.
Not yet at least. All it takes is one yahoo doing stupid sh*t and the authorities will start enforcing...But never enforced.![]()
They are enforced in California but in West Virginia i’m sure it’s a nonissueBut never enforced.![]()
I like the rear hub better than mid-drive the chain upkeep would be more and if when shifting gear with the mid-drive got stuck between the gears on the cassette gears under power you have a mess.
eBike Generation / Berry good points in your blog post re. an e-FTB for hunting being comforting to the spouse/family of the hunter for safety reasons is something I didn't think of but it's an excellent point. Covering the benefits of mid-drive vs. rear hub motor is good too, the benefits flip in the case of a broken chain... while the nod goes to the mid-drive, the rear hub motor being able to function (have power available) with a broken chain or a bent/destroyed derailleur is a plus... Thank you. ...Ride On!Last month I published an article that spoke specifically to hunters on which ebikes to look at and the difference between rear hub and mid drive, specifically fo rthe application of hunting/offroad. You should find some value in there: https://ebikegeneration.com/blogs/news/top-7-electric-hunting-bikes-for-2019
Drew - Is the polymer coating Dumonde Tech Original Formula Bicycle Chain Lube as good as the write up states? Sounds promising......It's clear to me I need to improve my chain maintenance regimen. Starting with going back to my tried-and-true oil-based chain lube (Dumonde Tech).
@Drew - Is the polymer coating Dumonde Tech Original Formula Bicycle Chain Lube as good as the write up states? Sounds promising...
https://www.dumondetech.com/portfolio/bicycle-chain-lube-bcl-original-formula/
Drew - Will be interested to hear how your Finish Line lube eval goes...Dumonde Tech worked pretty well on my MTB and hub drive e-bike. On those bikes it lasted a long time although it tended to gunk up the drive train. I haven't tried it on my mid drive yet, because I decided to try Finish Line E-bike Chain Lube. Still under evaluation!
Is the Finish Line ebike chain lube wet or dry?
Is the Finish Line ebike chain lube wet or dry? I use Finish line Dry Lubricant with teflon for the last few years living in the dry/sandy/dusty southwest. Any wet lube would quickly cause more damage compared to a dry teflon or wax lube.
