I have a Bafang bbshd 48v 14.5ah Sanyo battery bike, does great until about 50% power showing on display and on battery pack. When going up even slight grade with throttle battery will show no bars blink and power shuts off but still is showing about 400 watts but it’s not enough to continue. Let off throttle the battery display goes back up and shows 50% and 10 mile range.
Taking battery off at this point and testing voltage it is at 46.9 volts. Do you think that it is dipping that much under a load that it would be hitting the low voltage cut off. If so what good is a rating that is really only good for half of that if you try going uphill.
