Piper109,
Reading your feedback it sounds like you are looking for the following:
- Mostly riding on hard compact surfaces
- Looking for something with a mid drive system
- Looking to keep the price reasonable
- Looking for a quality bike
- As Chris mentioned above to which I agree with him, a wider durable tire like the Super MotoX is a great option. I am a big fan of this tire and put several thousand miles on my set.
I am not sure if you want just a Haibike but another option that covers what you are looking for is something like the
Cube SUV Hybrid Pro. Back in 2015 Court reviewed a
Cube Hybrid SL which comes with a belt drive and the Nuvinci Auto shift system. The 2016 Cube SUV Hybrid Pro that I am mentioning is the brother to the this and addresses pretty much every CON that Court mentioned (very few) in his review:
The SUV Pro comes with the following features that seem to be what you are looking for as standard equipment:
- Bosch Performance series mid drive system (*note picture shows the Active series but in fact the North American bikes come with Performance Series drives). An awesome drive system.
- Downtube mounted battery that really helps balance out this bike
- The bike is available in frame sizes 16 -18 and 20" frame sizes. For you an 18" - 20" frame would be the way to go based on your previous comments for your needs. This can be looked into a little further if you like the bike.
- The bike comes standard with the heavy duty Schwalbe Super MotoX tires that are 27.5 x 2.4" wide. And are perfect for the type of riding you mentioned you do and want to do.
- It comes with an 8 speed Shimano Alfine internal rear hub for ultra smooth shifting and is virtually maintenance free and offers the perfect gearing ratios for urban riding and hill climbing as you mentioned. All the maintenance that is really required is to lube your chain, just like on any bike.
- There is an air suspension front fork that you can dial in for your comfort level and it also has a lockout for those times for when you want a stiffer front end (eg.... hill climbing).
- The bike is made in Germany by CUBE so a top notch premium product.
- Only negative on the bike is the hard saddle. You will want to swap that out for sure. But then again most people swap out their MTB saddles for something different for urban / recreational riding.
- One of the big points you made was price. For just under $2650.00 USD ethe components and features on the bike appear to be what you are looking for compared to the models you mentioned. Just the components alone make this a very sweet bike.
hope this helps,
Will
