Ncm moscow :48 vdc 17 ah lithium battery , what is the low cutoff voltage ?
Tjay
Canada
Ncm moscow :48 vdc 17 ah lithium battery , what is the low cutoff voltage point ?
Fully charged its at 54Vdc.
I read somewhere that the ncm softeate cuts the battery off when it gets down to 42 Vdc ?
Is this fact ,?
I can give a bit of data - which may or may not be useful.
First I believe there is an LVC in both the Das-Kit Controller and also in the BMS of the battery. I'm assuming that whichever one is reached first will cause shutdown. I have 3 batteries that I use on my NCM bikes. I recently did some capacity tests on all 3 by fully charging and discharging each using an external load. Here's the results regarding end voltage::
Pack AhStart VoltageEnd Volltage
1354.0941.59
1654.0942.50
1954.1040.90
So the LVC for the packs seems to be around 42V.
I do not know what the LVC is for the Das-Kit controller.
