Nasty decals
Goof-off and goo-gone are good products for dissolving adhesive. One is slightly more organic, and one is full of organic solvents. Make your choice and test on a small area to make sure it won't hurt your paint.
The key is that it only dissolves the solvent. It doesn't destroy it. You need to mechanically remove it (scrape it, wipe it, etc) to actually get it off.
If you can't get to the adhesive directly it will help to peel off any top layer (even if it separates and leaves adhesive behind) or score the surface so that the solvent can reach the adhesive.
worse come to worse, use an eraser wheel; they attach to a drill motor, and make a huge crumbly mess, but the stickers will be toast. I used a couple to remove the big decals from an RV, stickers will be no big deal
A heat gun or hair dryer followed by wd-40 has worked on everything I have ever tried it on (bike frames, bike parts, tools).
The heat gun doesnt really do anyting other than soften the adhesive to allow easier removal of the decal. Adhesive almost always remains which is removed with wd-40
The decals on my surly bikes were very stubborn. Had to use a heatgun to soften the decal and then scrape with fingernails (wouldnt some off in one piece). Followed up with wd-40
Will try heatgun again, then everybodies favorite,Water Displacer Formula 40, thanx.
A co-worker gave me a box of plastic razor blades because I was so fascinated that such a thing existed. I've been trying to find a project to try them out!
My company used these wheels from 3M to remove lettering and decals from vehicles since the 90's. They work well and won't damage the paint. Not cheap though. There are some lower cost copies from other companies, I can't comment on them.
Some manufactures will clearcoat over decals; make sure yours are not. I had a Raleigh road bike that was clear coated over the graphics.
This guy compared 3 versions.
Now that is interesting,I would just like to borrow one from a friend, cannot detect clearcoat it is a matte finish.
Let's not add another page on deleting decals. Paint on top of it or stick another decal larger than one you want to delete.
Does this bother you? Paint is an option. Its rather interesting to learn new things, thought perhaps it was one of the goals of this forum :rolleyes:
I got plenty.
It's like watching a couple old ladies discussing the price of carrots.
I'm coming out of my cave.
I had some vado gummies, made me cockeyed, did sleep a little better though,cant get no decal pictures phone will not send to my"Hootersville" internet( at least it failed the other day :rolleyes: ) Ok one of the decals sez"power brings joy" and the other ones say something silly about electric bikeo_O
