Gary Shannon
Any idea what I should look for?
This is an AW 26" 48V 1000W front wheel from Amazon mounted on a Schwinn Meridian 3-wheeler. The unit is about a year old.
If I advance the throttle VERY VERY slowly it seems to work alright, but if I push the throttle at a normal, but gentle rate it bumps and jumps and then loses power.
With the front wheel off the ground, it works perfectly no matter how quickly I press the throttle. With the wheel on the ground I have to baby it to get up to cruising speed. Then it works fine while cruising, until the next time I release the throttle and press it again.
I thought it might have something to do with the controller getting a bogus "brake" signal and cutting power, but all the cabling looks fine from the brake levers.
