Moscow Light Output
jkvt
Anyone know the max wattage light that can be connected to the light output wire on the Moscow (Plus)? The wires look to be wired into the mount directly, so it's likely 48v output, but not sure the max wattage that can be output. I guess the limit would be whatever the wires can handle... whatever that is. Thanks!
It does run at full 48V and is on anytime the battery is on. If you run an LED headlight you shouldn't need to run anything over 20 watts to get a super bright light. Running 50 watts, about 1 amp, shouldn't be an issue. I'm running a 15W CREE LED light and it's plenty bright, even for daytime visibility.
This is exactly what I was looking for. Thanks very much!
